‎2012-05-21
07:27 AM
‎2023-05-26
04:38 PM
Rubia Torres
‎2012-05-21 11:34 AM
‎2012-05-22 07:59 AM
Erika wrote:You mean deleting the layout sheet and creating it again, right? That won't be of much difficulty. I'll try it.
Try re-saving the view after you the dimension tolerance set as you want it.
‎2012-05-22 08:16 AM
‎2012-05-22 08:24 AM
‎2012-05-22 08:25 AM
rocorona wrote:Great. I'll try this now. Thanks you so much.
No, Erika was referring to the VIEW.
In fact, if you switch the Navigator to "View Map", select your "wrong" View and click the Setting button, you can find the 2D/3D Document panel. Here is a pop up for the Dimension setting. You will see "Personal" if the Dimension style was not saved.
‎2012-05-22 08:39 AM
