Display malfunction of Graphisoft ID dashboard
Learn more
archigreen
Dimensioning issues
I need to change to 0'-0" on the automatic elevation dimensions.
When I go to Design/Story Settings I can't change to the dimension 0'-0" instead of 0".
Is there a way to fix it or do I have to live with it.
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
3 Replies 3
This is set in the dimensions prefs (options > project preferences) not the stories settings dialog.
archigreen
I've already tried but 0" does not change to 0'-0"
ArchiCAD 26
MacOS Monterey
64 GB
David Maudlin
archigreen:
Try these settings.
Bug: "-" sign is added to zero elevation dimension when showing zero feet, not shown when showing only zero inches (AC 15).
You should edit your Signature (click the Profile button near the top of this page) with your ArchiCAD version for more accurate help in this forum.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
