Dimensioning the Model
Srinivas
Attached is the image of a staircase railing detail. If am confident about modelling and I've done with it.
But How do I dimension the model? What I thought is that If we can save the model as a viewset and put that into the layout book and do the dimension. But ArchiCAD won't allow us to do dimension on Layout.
This kind of posibility is there in AutoCAD, Did I miss something in ArchiCAD?
Can someone suggest for a work around on this?
Thanks for all the help.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
6 REPLIES 6
Hi Srinivas,
What I have done sometimes is save the model view as a .3ds file and import into SketchUp (which is free) and then dimension it.
There is also a utility available on Objects Online called 3rd Dimension #114779 that seems to allow this in ArchiCAD. I have no experience with this though so can't confirm how well it works.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
David Maudlin
Also, see this thread:
3D Import Problems
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Srinivas
3D Import Problems
HTH
Thanks for the nice tip David, but I am unable to dimension the model perfectly, do I need to rotate the model more precisely to get exact dimensions?
ArchiCAD Service
Mac, Windows 11
Djordje
Save the 3D view as 2dl file or simply copy the contents of the flat marquee and paste in a separate view (storey or S/E - NOT the detail view, as you need dimensioning). Place the 2dl in the view, alternatively. It will come across as lines and fills, in correct scale. Dimension to your heart's content ...
When the detail is changed, repeat the process. No live 3D dimensionable view, I am sorry to say.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
The Dimensioning Tools can be used in the Detail window. I think this is the best location for this type of detail that is not part of the live model.
You should check your settings in the Parallel Projection Settings dialog box. Make sure the "h" values match, and that you have selected a predefined Axon view (not custom). If your view comes from Orbiting around, these values can be strange.
HTH
Djordje
You are right; even the marker can be placed accordingly. And there are no existing dimensions not to be transferred.
Correct.
Even if you have orbited, open the 3D window settings and set all the axis scale factors to one. Then the dimensioning can commence.
Djordje
HP Omen
