ā2007-02-13
06:32 PM
ā2023-05-30
03:22 PM
Rubia Torres
ā2007-02-13 09:25 PM
ā2007-02-13 10:21 PM
ā2007-02-13 10:28 PM
Oreosh8ke wrote:Dimension Standards (Options>Project Preferences>Dimensions...) are saved with each view (View Map).
I've been told that we're able to display the dimensions in feet/in AND in metric at the SAME time.
Is this true? And if so, what settings do I alter?
Thanks in advance!
ā2007-02-13 10:38 PM
Oreosh8ke wrote:Ah yes, secondary dimensions will give you what you want. Assuming you have the add-on loaded (you will see it under Document>Document Extras>Secondary Dimensions), you simply dimension your model in one format (eg. imperial/metric), then convert them all to another format. You can select specific dimensions if you just want to convert a select amount. This will add the other format to the existing string. If the model changes, you will need to 'refresh' these converted dimension strings to make sure the extra format updtaes too, as it is not automatic, even if the dimension is associative.
Archicad 10
I've searched for help and is think the secondary dimensions (add-on)
Does anyone know how to set that up?
Thanks,
ā2007-02-13 11:28 PM
