Gus
Dimensions are at a 45 degree angle?! Please Help
Every time I try to draw a dimension line on my floor plan I click one side of the dimension then the other then when I double click to get the final thing (where I usually adjust the leader length) it puts the marker down with the dimension but everything (the dimension line) is at a 45 degree angle. I use the dimension tool on one of my independant worksheets and everything works fine. Its just on my floor plan where it changes the dim line angle. Anybody know how I can fix this. I'm sure its just a setting somewhere but I can't find that setting for the life of me.
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
1 Reply 1
Which geometry method are you using?
X-Y Only or Any Direction?
Is your Grid rotated by any chance?
