We value your input!
Dimensions changing in the layout view when I place a worksheet
The dimension lines that I make on my worksheet change values when I place the worksheet on the layout tab. 1st image is the worksheet view where i added the dimensions and the 2nd image in the layout view, where on the left I've added the worksheet and the dimension values have changed. On the right I have added dimension lines to the section from which I have created the worksheet and tried placing that into the layout and that comes perfectly fine.
Any help as to how to get the accurate dimension for the worksheet too in the layout view?
Podolsky
Ace
Never have seen something like that.
Is it possible, that in view settings dimensions are set to meters? Then program is rounding meters - 500mm actually is 0 meters.
Please check view settings.
Thanks a lot, that fixed it for me! The source view settings was set to meter for some reason and after changing it to mm its reflecting the correct number. Thanks again!
