2004-09-11
04:07 PM
2023-05-30
03:28 PM
Rubia Torres
2004-09-11 08:04 PM
J.R wrote:Not without a custom GDL object (or custom API programming). There is one at objects online that I just found - had a memory of seeing it once:
is it possible to draw dimensions on 3D view in ArchiCAD 7.0?
2004-09-12 09:03 AM
J.R wrote:The workaround you might look for is to copy the 2D linework from the analytic hidden line 3D view to an appropriate storey or dummy elevation and dimension there; of course it is not associative and will require complete reworking if changed (as if it always isn't ...)
2004-09-12 12:21 PM
