‎2007-12-01
01:55 PM
‎2023-05-23
12:02 AM
Gordana Radonic
‎2007-12-02 02:56 AM
‎2007-12-02 03:55 AM
‎2007-12-02 05:01 AM
Richard wrote:Hi Richard, Nice to meet you and thanks for the reply!
I think it would be helpful to have a little more information. For example,
1. Are you using the latest update? If not, try updating and see if this helps.
2. Are you in a Detail window? Section Window? Plan window? What is the scale of the window as you're dimensioning?
3. You might try selecting the problem dimension and then open up the dimension dialog box and post a screen shot of that.
‎2007-12-02 05:16 AM
‎2007-12-02 05:43 AM
‎2007-12-02 07:22 AM
‎2007-12-02 08:40 AM
‎2007-12-02 11:43 PM
‎2007-12-03 07:41 PM
Richard wrote:Hmmm...we have run across this as well (AC10) in detail windows -- couldn't tell you if it was in the Project Map or View Map, but will investigate if it happens again. Regardless of "scale", it sounds like a bug to me...
I think this is certainly a scale issue. It appears that your dimension text size is being placed as a "fixed" size, which will get screwed up when the scale is not correct. (Changing to a view using the Project Map doesn't change scale properly, whereas using the View Map does (as long as the scale is saved correctly), as you've discovered.
