2024-07-01 05:20 AM - edited 2024-07-01 05:20 AM
why is the drop panel dimesion locked? I also want to change/add a surface to put a material
Solved! Go to Solution.
2024-07-01 05:55 AM
It is a segmented column, so you have to press the 'Cross Section Size' button.
Then you will see a pop-out where you can select the segment that you want to adjust the size of.
2024-07-01 05:55 AM
2024-07-01 08:25 AM
THANK YOU!
