bibiarch
why is the drop panel dimesion locked?
why is the drop panel dimesion locked? I also want to change/add a surface to put a material
1 Solution
It is a segmented column, so you have to press the 'Cross Section Size' button.
Then you will see a pop-out where you can select the segment that you want to adjust the size of.
Go to post
2 Replies 2
bibiarch
THANK YOU!
