Disappearing view maps on refresh
View maps disappear during refresh, has anyone solved this?
Saw a few earlier similar queries, but no answers.
Many thanks
Mike C
12 Replies 12
Seems I found a way to have things going back right :
1 - remove the drawing from the layout.
2 - Go into Organizer (the window in wich you have drawings, 3D view, views, plans and so on)
3 - take the view in the organizer window - and place it into the Layout.
4 - Alt-Click (take defaults parameters with the syringe) on the drawing in the layout to restore default parameters...
It seems there is an hidden parameter that makes the view map translate in the layout.
I am facing the same problem & I think i have found a solution. please let me know if this is correct.
If I click the 'use internal origin' in the anchor point menu of the drawing properties the drawing stays where it is in the layout.
Hope this is the right way.
Regards
Ameya
It works on one computer - not the other one...
