Display order issuse with stairs in plan
trek1357
I have a sofa under my staircase, however, despite how much I change the objects cut or uncut fill it still displays it as a solid above the stairs in plan view.
If anyone can help me please I would greatly appreciate it.
Thanks
@trek1357 wrote:
I'll give it a shot, I didn't realise that you could change the display order of objects.
Looks like you've got some reference manual reading to do. 😀
https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F030_Inter...
All elements have a default display order.
As stairs and the sofa are both objects, they will have the same default display order, but the one you place last will show on top.
4 REPLIES 4
Have you tried adjusting the display order (EDIT menu > Display Order)?
Send the sofa backwards or bring the stairs forward.
Hey, thanks a lot really appreciate it.
Setup info provided by author
