2021-01-24
		08:36 PM
		2023-05-22
		11:51 PM
			Gordana Radonic
2021-01-24 10:07 PM
2021-01-25 03:17 AM
2021-01-27 02:34 AM
2021-01-28 11:16 PM
2021-01-29 01:52 AM
Josh wrote:
A mesh tool that doesn't display in plan view, the way it does in all other views.
A level dimension tool that can't return the dimension level of the element it's associated too.
2021-01-29 05:40 PM
2021-02-01 07:50 PM
Barry wrote:Hi Barry
The mesh tool does display in the plan view as it does in the other views.
It is the Solid Element Operation that does not show.
If you edit the mesh by adding contours and adjusting levels, or in the example you show, cut a hole and add another mesh inside, you will see exactly what you want and you can use the level dimension tool.
2021-02-01 08:00 PM
2021-02-01 08:06 PM
James wrote:Thanks James, I didn't realise the opening tool worked on meshes as well.
To cut into a Mesh, you could also try to use the Opening Tool (added in AC23).
Which you'll see on the Floor Plan.
I made a video early last year, you can skip towards the end.
