Door Symbol in Elevation
How do you change the size of the door label? It is grayed out. Thanks.
Steve Jepson
It depends on which Label you are using. Uncheck the Fit to Frame to Text box and it will let you type in Frame Height, Frame Width.
Steve,
Thanks. It worked.
