‎2014-09-26
09:55 PM
‎2025-02-06
11:16 AM
Aruzhan Ilaikova
‎2014-09-27 02:05 AM
‎2014-09-27 06:41 PM
‎2014-09-28 12:42 AM
‎2014-09-28 07:46 AM
Karl wrote:
Not that arduous - just click the Window tool, ctrl-A (cmd-A), to select all windows, ctrl-T (cmd-T) to go to settings and check the label box.
The logic is that you have control over every section/election as to whether the marker is displayed. If it displayed always, you might be complaining about how to turn the markers off in your sections.😉
Another possibility is that you may not want to label all windows. Perhaps its a remodel and you want all windows to show, but to only have labels for the new ones.
With 4 typical elevations, no big deal. If your project has angled wings and has lots of elevations due to that, then, yeah, it is a bit time consuming.
‎2014-09-28 09:59 AM
‎2014-09-28 02:54 PM
Jonathan wrote:Use the Label Window Marker 18 and check Use symbol arrow.
There is no option to remove the arrow in the label tool.
Jonathan wrote:Use the Label Window Marker 18 and under Symbol Label > Options > Polygon Shape > Rectangle.
If there was an option ... and the ability to select the shape of the label box the ID is in, this would work for me.
‎2014-09-28 06:08 PM
‎2014-09-28 07:34 PM
‎2014-09-28 07:46 PM
Stress wrote:
With regard to label rotation...
are you using the Window Marker or the Door Marker?
The Door Marker did not work correctly (for me) in AC 17.
See: Door/Window Markers in Elevation
