Marko Vuckovic
Door schedule, Nominal vs Rough openings
Hi Archicad community!
I need an explanation on how to get nominal and rough door openings for my door schedule. These are the main two parameters that I need, and I struggle to make my schedule reflect the actual door sizes.
Besides getting the actual sizes in there without manually typing them in, I'm unsure how to fix the dimension precision correctly. One image represents the actual door size in 1/8" precision, but when I click out from the table, the number gets back to 1/4" precision (another image).
As for the rough opening, it should be 1" wider and 1/2" higher in total, and I can't find where to set this up in the door settings.
Attached is also the type of door that I'm using for this project.
Thanks!
Marko
Screen Shot 2022-07-26 at 8.51.34 AM.pngScreen Shot 2022-07-26 at 8.51.26 AM.pngScreen Shot 2022-07-26 at 8.52.41 AM.png
2 Replies 2
What is the difference between Door D10 and all the rest? Are you using a different Library Part? Or do you set something differently than the rest?
Dora Oliveira
Hi Marko,
Could you add the window's Rough Opening automatically to your schedule?
I also need that info and the R.O. field is not available to be included in my schedule. Any advice?
Thanks.
