Doors in Curtainwall tool
jkershaw
I have placed doors in a curtain wall. Yay.
Now, by what secret combination of settings do I get those doors to read properly in plan (showing door swing) AND in RCP (not showing door swing). I can't seem to pull it off, having tried using multiple combinations of Model View Options and curtain wall tool Floor Plan Display Settings.
This cannot be so difficult. Doors placed using the Door tool work properly.
Thanks!
AC 17 on an iMac 2.7GHz Intel Core i5 with 12GB RAM
AC26 APPLE SILICON USA FULL 4032
Mac Studio 2022, Apple M1 Max, 64GB RAM
13.2 macOS Ventura
learning AC since version 4.5
4 REPLIES 4
Are these the two options you wish to achieve?
See attached image.
jkershaw
thank you for the reply!
The RCP in your example is not quite right. On the RCP, we should see "wall contour" lines - or in this case, the contour line of the curtain wall frame above the door.
That's where I'm having the issue.
13.2 macOS Ventura
Unfortunately I cannot offer you an easy solution for that scenario.
You could just draw those lines with simple Lines.
I would place those lines on a separate layer that would be visible only in the Layer Combination created for the Reflected Ceiling Plan.
sinceV6
Hi.
Or better yet.... cut out the door from the curtain wall contour and place a normal door in a wall (same size as the door so it doesn't show). Doors will be easier to manage, schedule, tag, dimension and modify this way.
Best regards.
