Seiss Wagner
E-mail from Publisher
I need help in setting up the e-mail connection in PlotMaker Publisher.
I have no internet Host Name, I have no User Name, I have no Password; this all sounds like an FTP account to me.
I am using DHCP, I do have an IP Address, I do have a Subnet Mask, I do have a Router, I have no DNS server, I have no Search Domain.
Options>Preferences>Publisher>My E-mail options are set correctly.
How do I make a connection??????
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
3 Replies 3
Ben Odonnell
Seiss,
Is it possible that you are mixing up you FTP server info with your mail sever info?
See the attached image for an explanation.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Seiss Wagner
BEN -
Thanks for your response. No I was not confusing the ftp set-up in Publisher with the e-mail set-up in Preferences.
However, I was confused in thinking that Publisher could e-mail a published document. That is not the case. Publisher can only send an information e-mail corresponding to a specific ftp upload.
In any case the problem still presists, that is Publisher will not send the e-mail as it claims not to be able to find the mail server. My server address begins with smpt and reads "smpt.pacbell.yahoo.com" so I don't understand why publisher can't find the server as the resident e-mail program finds it just fine.
Also, when I provide the ftp address publisher publishes, and then claims it could not find the host, but the log shows the transaction was completed. I don't understand all this confusion.
Tomorrow I will check to see if the test document went to the ftp site. I know the e-mail failed because I sent it to myself.
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Are you sure that "smpt.pacbell.yahoo.com" is not "smtp.pacbell.yahoo.com" ?
The publisher creates the files first, before launching the FTP uploader. Therefore the publishing will report success, even if you have a problem with uploader.
Can you paste here a screenshot of your settings?
Gergely Kmethy
VP, Customer Success, Graphisoft
