Tom Krowka
Elevation lineweights
What is the best way to show thinner/wider lineweights in elevation so the drawings appear closer to farther away.
I've done it in section, but nothing seems to work in elevation. Is that something I would have to set up in the pen weights in each wall? That would seem to be very time consuming.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
11 Replies 11
I also outline. With the hatching on, I outline the foreground planes, leave the middleground alone, and use the marked distant area for the back. I use a black hairline instead of grey. This gives three levels which is usually enough.
Matthew, I've tried that method, but I've found that on a complex model (lots of curvy trim) I get erratic results even with the model perfect. With a lot of straight stuff, it's definitely worth it. If you use linked sections, it's no trouble to keep an unlinked one just for the purpose.
James Murray
vfrontiers
Dave wrote:
Matthew wrote:
I have found a neat trick I call shrink wrapping. It goes (briefly) as follows...
If people are interested I can post a PDF showing the technique later when I get to the office.
Neat trick indeed, Matthew. Please do post when you get a chance.
Wow Matt, you really know how to steal a man's thunder! This is always an "eye-opener" and I was planning this "smoke and mirrors" for ACUWest... Damn... Guess I'll have to come up with something new... It did get some OOOhs and AAAhs at ACUE 2002....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
