Your signature says you are using version 19? (I see colour in your icons so that must be correct).
This is a known issue in later versions.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70970&p=317521&hilit=layout+rotate#p317521
Make sure you have the latest update for your version and maybe try the 'Open & Repair' option on the file.
