Elevations/Sections rotated in Layout + Elevation Dimension up-side down
I have a problem with a file where all sections and elevations looks fine, but are rotated once placed in Layout. In addition to this, the elevation dimensions are ok in the view, but up-side down once the view is placed in a layout.
The Angle of the drawing is 0,00º in Drawing Selection Settings, so this is not the issue.
What might be the problem? The only thing I can think of is that plan view is rotated 87,01º, but I assume that this doesn't affect the layout.
See screenshots:
1 - View
2 - View placed on Layout
3 - Plan
Your signature says you are using version 19? (I see colour in your icons so that must be correct).
This is a known issue in later versions.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=70970&p=317521&hilit=layout+rotate#p317521
Make sure you have the latest update for your version and maybe try the 'Open & Repair' option on the file.
What happens if you rotate the Viewpoint 90 degrees clockwise so its rotation angle will be -2.99 degrees instead of the current 87,01 degrees. Does that give better results on Layouts?
