Elevations and Sections Markers
Merry Christmas to Everyone
There is a way to automatic chance the scale of section marker or elevation marker automatically when you switch from a site plan to floor plan if there are in different scale?
Thanks.
4 Replies 4
vistasp
Mentor
Save views at different scales in the View Map?
Or am I missing the point of the question?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Thanks and Merry Christmas
I was referring to a saved view
You could save the view set at the same scale and then change it to suit in the layout (Drawing Selection Settings>Properties>Drawing Scale) - this will reduce or enlarge the whole view to the preferred scale, which may not be suitable with regards to other text/labels/dimensions which you may want to keep consistent.
I would suggest a better option would be to copy and paste the section/elevation markers to a site plan only layer, adjust sizes of marker to suit required scale and change settings to be linked markers to the original markers.
Thanks.
Happy new Year and thank you for the nice and appreciate suggestion.
