Embedded layers of drawings (dwg)
giza
Is there an option that you re show embedded layers of drawings dwg.
there is this option to hide them from ArchiCAD drawing but than how to show them back if required, i tried with updating the drawing but it does not
how to hide embedded layers can be found https://helpcenter.graphisoft.com/user-guide/66067/
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
I don't think there is an option to 'un-hide' an embedded layer.
But then I don't seem to have this option to hide them either - but that just be my Work Environment.
But no matter.
Open the drawing settings then open the "Drawings own layers" and turn on/off whatever layer you want.
But no matter.
giza
Thanks a lot Barry.
