‎2019-08-10
06:28 PM
‎2023-05-19
03:22 PM
Gordana Radonic
‎2019-08-12 03:18 AM
‎2021-04-01 02:38 AM
Barry wrote:Not being able to export/import Graphic Override Rules on their own is unbelievable and I am surprised this was the only thread I could find that it was even mentioned. Talk about our time-wasting, and yet another example of a poorly thought out tool usability wise. Nothing changed in 24.
All a bit messy if you ask me.
Archicad should ask if you want to update the existing rules when you import or allow us to import the rules searately.
I haven't checked if it will be any different in 23 but I know there has been some changes in how views deal with 'missing' settings.
‎2022-08-22 03:39 AM
Same issue here - one can import/export many Model View Options at once (AC25). But for some reason GO's can only be exported one by one. On the contrary, apparently many GO's can be imported at once... weirdly inconsistent. Maybe AC26 fixes this but we're not going there yet.
‎2022-08-22 04:48 AM
Yes it does.
‎2022-08-22 06:08 AM
Thanks Barry good to know!
‎2023-05-17 12:27 PM
Unfortunately, 26 does not fix this issue.
‎2023-05-17 01:57 PM
In 26 if you import a GO it will copy the rules across by it will not overwrite an existing rule with an identical name. You have to remove the rule/s first and then import the GO.
‎2026-02-26 07:24 AM
Still does not give the option to override in AC29... Zzz...
