2023-12-15
03:29 PM
- last edited on
2025-01-14
08:11 PM
by
I work as the sole architect in a big construction company and every day I make a lot of changes to several projects, and that demanding workflow prevents me from using the issue-revision-changes manager which is too complex.
Instead, I input those changes into the Project Notes tool.
I would like each time I publish the updated drawings to be able to publish the Project Notes as well.
This would be great for people who don't use Archicad to have easy access to the event log.
Is there any other way except the copy-paste method?
P.S.
I wonder why it 's not possible to export project notes to any kind of file (txt, xls, doc....) or at least as a worksheet to share with the rest of the team!
Thank you in advance
Solved! Go to Solution.
2023-12-17
03:28 PM
- last edited on
2023-12-19
05:31 AM
by
Hi ST, you can save the project notes as a View and copy them to the Publisher set. Once it is in the publisher set, you can save it as PDF or List, as in the attached snapshot. I hope that helps. Best, Viviana
2023-12-17
03:28 PM
- last edited on
2023-12-19
05:31 AM
by
2023-12-19 08:05 AM
Thank you Viviana! You are a boss...!
