ā2010-10-25
09:06 AM
ā2023-05-26
02:29 AM
Gordana Radonic
ā2010-10-25 09:20 AM
ā2010-10-25 09:32 AM
ā2010-10-25 10:44 AM
ā2011-01-23 08:59 PM
ā2011-01-24 04:49 PM
Achille wrote:Sounds like a bug/glitch. Stick with the PDFs.
hi, i have this problem: i created a new fill for insulation using lines which i copy-pasted. I placed the fill within a composite wall with the "fit to skin" option enabled. The fill appears correctly on screen, BUT when printing large portions of the fill are NOT printed, i.e. are left blank.
If i publish to pdf and then print, then the fill prints correctly...
any suggestions/ideas?
ā2011-01-24 04:55 PM
ā2011-01-24 05:03 PM
Achille wrote:That's strange. I haven't noticed any color variance between the printing methods. It's been a while since I've done much really fine tuned color work though. I suppose this may be due to ArchiCAD's use of RGB color space while PDF (I think) uses CMYK. What PDF program are you using? I use either Acrobat or the Mac's built in functions.
That's really bad...
the colours at the pdf do not print exactly as from archicad...
ā2011-01-24 05:07 PM
ā2011-01-24 05:15 PM
