Floor Plan Cut Plain
EXPODTL
How do I fix the floor plan cut plane?  I know how to set it but it keeps reverting back to what was pre set in the program!  My plan will not display correctly without this command lock.  I do push ok once set.
Thanks again!
1 REPLY 1
David Maudlin
EXPODTL:
The FPCP is part of a View (like its Layer Combination). Set the FPCP by selecting the correct View, open its View Settings, then under 2D/3D Documents click the Floor Plan Cut Plane... to set its parameters. Now when you open that View, the FPCP settings will be correct.
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
