Floor Plan Cut Plane logic?
Ernest Atanasiu
Hello there,
I don't understand the logic of Floor Plan Cut Plane (global setting) = FPCP.
There is a global setting, each view has a setting which overrides it, I guess.
but...
If you have a detail marker already in place and you modify the FPCP value everything goes bananas. The detail never picks up the change of the FPCP and after working in the detail, the FPCP resets itself at the default value (1.00m).
Only solution is to redraw the detail marker but this tedious and not quite OK for us.
Anyone could enlighten me, please?
Thank you.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
2 REPLIES 2
This is a curious limitation and I honestly don't know why there is such a limitation.
Seems like it stores the FPCP setting in effect at the time of its creation and this cannot be modified later no matter what you do. You would have to create a new Detail Viewpoint to change the FCPC settings.
Ernest Atanasiu
Yes, that is correct.
I have found a workaround by going through each detail and resetting the FPCP value, sort of.
First you have to set-up the project map view of the plan, select the detail and open it with current view setting option (right click). Then Rebuild from Source View and finally Redefine With Current Windows Settings in the View Map.
