Hello there,
I don't understand the logic of Floor Plan Cut Plane (global setting) = FPCP.
There is a global setting, each view has a setting which overrides it, I guess.
but...
If you have a detail marker already in place and you modify the FPCP value everything goes bananas. The detail never picks up the change of the FPCP and after working in the detail, the FPCP resets itself at the default value (1.00m).
Only solution is to redraw the detail marker but this tedious and not quite OK for us.
Anyone could enlighten me, please?
Thank you.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
