Floor Plan Cut Plane
The selected setting for the Floor Plan displays the plan correctly, however, it does not update in the View or the Layout.
Not only does that but when I display again the Floor Plan, the <Documents> <Set floor plan cut view> resets back to the program default setting.
Any ideas how to retain the setting for the specific floor level ?
As always, grateful for your help
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 Replies 3
David Maudlin
Conrado:
The Floor Plan Cut Plane (FPCP) settings are saved as part of the View. Select the View in the Navigator, click the Settings... button, then in View Settings > 2D/3D Documents > click the Floor Plan Cut Plane Settings... button and set the FPCP Settings as desired, then click OK. These settings should be applied when double-clicking that View in the Navigator, and be part of the Drawing of that View on the Layout. This allows different FPCP Settings for different Views.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David.
Reliable help from Washington when is needed
David Maudlin
HA!
David
