ā2013-05-15
05:53 AM
ā2023-05-19
10:14 PM
Gordana Radonic
ā2013-05-15 06:00 AM
ā2013-05-15 06:07 AM
ā2013-05-15 07:02 AM
Matthew wrote:
The simplest way is to overlay drawings on the layout.
ā2013-05-15 07:18 AM
ā2013-05-15 08:58 AM
ā2013-05-15 09:04 AM
Barry wrote:
You need to create a new pen set with your very light pens.
Than apply that pen set to the drawing on the layout that you want to show as your ghost.
ā2013-05-15 09:27 AM
ā2013-05-15 09:47 AM
ā2013-05-15 05:53 PM
Barry wrote:
To create a pen set go to OPTIONS menu > ELEMENT ATTRIBUTES > PENS & COLOURS.
You can select all the pens at once and edit the colour so they are all the same - saves doing each one separately.
You can also change the pen thicknesses but you will probaly want to leave them as they are.
Then store the pen set with the name you want.
Now when you place a drawing on a layout you can set it to use the ghost pen set as shown in the previous image.
You could also save a view of your plan in the view map that uses the ghost pen set.
But this means you might need to duplicate your plan views - one with the standard pen set and another with the ghost pen set.
Changing the pen set used in the "drawing settings" on the layout means that you can place the same view on the layout and change its pen colours without having to create duplicate views of the same plan with different pen colours.
Much of a muchness either way really.
