Yvonne wrote:
The views are correct. It seems to be a glitch as it's appearing on lines etc from the master layout
The layouts (and masters) do not have graphic overrides of their own.
Only the drawings (views) have the GOs as per their settings.
However, the elements in a master layout can appear a different colour if you have the option set in the Work Environment > On Screen Options, to use a uniform pen colour for master items on layouts.
This setting does not affect the printed output, it is just an on-screen option.
If that is not it maybe you can post a screen shot of the problem.
