Brandon-W_DWa
Graphic Override Combinations - "Affected View" Count
I am cleaning up our firm template, and currently purging unused Graphic Override Combinations. When I delete (4) of them, I get a message that tells me how many views are affected. Great - very helpful information:
However, I've gone through all of my views to find the affected ones (in which I now need to change the Graphic Override to another combination or "No Override"), and I have only found 40 (46 if you include the parent clone folder). Are there other views somewhere that I'm missing, or is this number just wrong? Another idea - are there other elements I'm not thinking about that can have a GO assigned to it? Thanks!
Operating system used: Mac Apple Silicon 14.7.1 Sonoma
Dake Wells Architecture
Version 28.3.3
2021 MacBook Pro 16", M1 Max Chip, 64gb DDR5
Browser: Google Chrome
4 Replies 4
Matteods
Hi in archicad you can check your views using the view list. You will get a list with all views created and which graphical override is assigned to them
Could you show a screen shot please?
I am not familiar with a 'view list' that shows the graphical override used.
Do you mean open the Organiser palette?
Matteods
Hi Barry
I work in an office and we work on the swiss version so I don't know the exact name in english.
But it should be these: the project indexs
https://help.graphisoft.com/AC/19/INT/AC19Help/03_2_Views_Virtual_Building/03_2_Views_Virtual_Buildi...
Have  a look to it. If you search it you should have one already made for views
Yes, I didn't think about the project indexes.
You can even create one that looks only for specific Go in the criteria and then list the view map and view name in the fields.
Or if you open the Organiser, you will see a more detailed list including the GO used.
You have to scroll through the list one by one, but you can see the GO used, unlike in the Navigator.
