Vern
Graphic Override combination option in this view is not editable
Hi All
I am having an issue where I place a detail marker (source marker) on a floor plan and then go to save the view in the view map, but can't change the graphic override on it. Any ideas on why this is?
Thank you in advance.
6 Replies 6
See Barry's comment below.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
This may help.
https://community.graphisoft.com/t5/Document-Visualize-forum/Problems-with-changing-Graphic-Override...
Vern
Okay, thank you Barry.
Thiefsie
Is there a way to get this to stick/save? I can re-assign the override (which is weird as the view the detail is being pulled/rebuilt from has no override at all applied), but as soon as I redefine with current (correct) settings it goes back to the wrong GO...?
This is infuriating as on the sheet the view is showing the override and I can't seem to get rid of it.
I am not sure as I try to avoid details at all costs.
I use sections instead.
But maybe you will have to do it twice.
If the source view is already set as you want, then change it to something else that is totally wrong.
Then redefine the detail with that wrong setting.
Now go back to the source and set it as it should be.
Redefine the detail now with that setting.
I am not sure if it will work, but give it a try.
Unless you are working in teamwork?
Then you may need to check if you have the correct permission to make these changes.
Thiefsie
Looks like I had to delete the view on the sheet and create a new one.
