Graphic Override not working correctly....I think
Liamthanks
Hi guys,
Scratching my head with this one. I've create a GO to have everything EXCEPT the Electrical related layers show up in a light grey and the house plans shows exactly as I want it. However for whatever reason this GO is overriding the layers that I want excluded as well. To confirm, all of the elements I want excluded are on one of those layers shown in the GO view.
What am I missing??
AC27 Build 5060 AUS - Windows 10 Pro, Ryzen 7 5800X, RTX 3090, M.2 NVME 0.5TB SSD, 32GB RAM
Without testing it I think it is just a case of changing all of the 'OR' to 'AND'.
I was going to suggest to use brackets around the group of layers but GO do not have brackets like the schedules do - not sure why.
Liamthanks
Hey Barry!
Yeah it is odd that there are no brackets like there is in the Schedules!
Changing the 'or' to 'and' has done the trick. To me that's saying that the objects have to be on all of those layers, which to me doesn't make sense, but if it works then I'm happy.
Thanks for that
But don't forget you are saying 'Is Not ' in that layer.
So it is not in layer one and it is not in layer two and it is not in layer three, etc.
