We value your input!
Graphic Overrides - Reflected Ceiling Plans.
Viktorhgo
Hi All,
Whenever I applied the Reflected ceiling plan override, some of the window line contours don't show up, it only happened with windows, not with openings and doors. I´m attaching a  screenshot, if any has a solution that would be appreciated.
Best Regards.
Josh Verran
Hi there
It could be Model view options or Graphic Overrides.
To troubleshoot, if you have a view where they do show, try temporarily switching the Model View Options to one you know works? That will rule out MVOs.
If you switch the Graphic Overrides to no overrides, that would rule out GOs.
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
Josh Verran
If it was MVOs, it would probably be this
