Viktorhgo
Graphic Overrides - Reflected Ceiling Plans.
Hi All,
Whenever I applied the Reflected ceiling plan override, some of the window line contours don't show up, it only happened with windows, not with openings and doors. I´m attaching a  screenshot, if any has a solution that would be appreciated.
Best Regards.
2 Replies 2
Josh Verran
Hi there
It could be Model view options or Graphic Overrides.
To troubleshoot, if you have a view where they do show, try temporarily switching the Model View Options to one you know works? That will rule out MVOs.
If you switch the Graphic Overrides to no overrides, that would rule out GOs.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
Josh Verran
If it was MVOs, it would probably be this
