Graphical override rule based on door dimensions
This post is a follow-up to a thread that was not answered on a French-language forum : https://www.archi-cadlink.fr/viewtopic.php?p=39523#p39523
The topic is : "Is it possible to create a graphical override rule based on door dimensions ?"
Creating a graphical override rule based on the generic width of a door is not sufficient, as the goal here is to color in doors that do not allow sufficient passage width for a wheelchair.
Operating system used: Mac Ventura
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
3 Replies 3
Matteods
Hi
I did a try. You can use the general rule width, but then for the door size you need to choose and select the following one:
In this way is working for me 🙂 Let me know if it helps.
Greetings,
Matteo.
Thanks about your answers but as I said ...
Generic width of a door is not sufficient, as the goal here is to color in doors that do not allow sufficient width for wheelchairs.
Christophe - FRANCE
Archicad 15 to 29
Matteods
Sorry here should be egress dimension the number 4. It's true tha you don't have a dimension with the door leaf open that is what you are looking for. So you need to study which is the minimum dimension 4 to insert in your graphical override rule. Hope that you have the same doorleaf everywhere 🙂
