Grid in Plotmaker
I attempted to use the GRID fuction in Plotmaker to help organizing a series of details in an orderly way.
However, I cannot find any way to set the grid origin (or an intersection point of the grid) at a desired location in the Layout.
The Grid origin defaults to one corner of the Layout which is useless since Layout have usually a Title block.
Is there any way to set the grid origin at a selected point ?
Conrado Dominguez
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
2 REPLIES 2
Use the Aux. grid with a step of 1 to move the start point of the real grid. It takes some experimentation to center the grid on the sheet.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
tsturm
The grid tool is nice to use but often hard to set up.
I have preferred to use hotspots on the Master page. You can set them on a layer which could be shut off it you choose.
I set up our pages using the Uniform Guidelines for the page grid system.
So my hotspots are 5 3/4" apart running vertically and 6" running horizontally.
Snap points exactly where I want and coordinated to every kind of Master Layout that I plan to use.
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
