HP DesignJet 5500 on Vista: Rotation Problem
I've been having a problem with output from vista in general with my 5500. Anything that I try to plot over 24" wide gets scaled to 24" wide. That is, if I try to print an Arch D sheet on a 36" roll, the printer doesn't recognize that I have a 36" roll, so if I print it landscape format (36x24), it scales the bottom edge of the plot to 24" wide.
Has anyone located any modded drivers, or a workaround for this problem? I looked on HPs website, in a few of their forums, and there were quite a few posts stating the same problem that I'm having. . .however, I still haven't located a solution.
This happens not only with ArchiCAD but with EVERYTHING on Vista. . thank you HP and Micro$oft.
Sytem Specs:
Manufacturer: ASUS G1S Notekbook
Processor: Intel(R) Core(TM)2 Duo CPU T7700 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 4 GB RAM
Hard Drive: 320 GB
Video Card: NVIDIA GeForce 8600M GT
Monitor: 1680x1050 res
Sound Card: Embedded
Speakers/Headphones: Plantronics Gaming Headset
Keyboard: Embedded
Mouse: Logitech G5
0 Replies 0
