2005-06-16
01:47 PM
2023-05-19
12:19 AM
Gordana Radonic
2005-06-30 10:10 AM
Philippe wrote:yes - they collect the bugs and channel it officially back to graphisoft for fixing. that's not to say graphisoft don't respond here because they often do: but to be assured of a bug getting back to HQ report it to your dealer/reseller . . .
Do they suppose to collect bugs?
I thought this forum was the right place to get answer to problems.
2005-06-30 09:20 PM
Philippe wrote:Yes, people on this forum can answer problems and can offer solutions.
Why not?
Shouldn't change that much for me…
2005-07-01 08:01 AM
laszlonagy wrote:Ok ok I did it. But I saw so many people around here announcing bugs and be blamed to be just Re*it advocates (you notice I avoid the randomizers to jump on that
But if you found a bug, it should be fixed, and the standard line to let Graphisoft know about it is to send bug report to your local reseller, who will make sure it gets to Graphisoft and gets fixed.
2005-07-01 11:17 PM
Philippe wrote:This is one of the great values of this forum. If you find yourself unable to do something you can probably get an answer or a workaround, or, if it truly is a bug, it will become apparent and can be confidently reported.laszlonagy wrote:Ok ok I did it. But I saw so many people around here announcing bugs and be blamed to be just Re*it advocates (you notice I avoid the randomizers to jump on that
But if you found a bug, it should be fixed, and the standard line to let Graphisoft know about it is to send bug report to your local reseller, who will make sure it gets to Graphisoft and gets fixed.), I feel myself like most of the common Ac users unable to determine if it's a bug or not.
I am not a big user of forum but so far, I saw veterans checking most of the messages. So what silence signifies?Silence usually means:
• "you found a bug , report it and stop irritate me"
or
• "you are incompetent, do your homework"
