Hide what's behind windows in elevation
Hi!
Im doing a big elevation of a school facade. I don't want things that are in the classroom behind the windows (chairs, doors etc) to be visible in the elevation.
I just want it do be the facade.
Is that doable?
Hope I explained it good enough
M
4 REPLIES 4
Dontknow
Turn off the Transparency in the elevation settings.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thanks for the reply but when i uncheck the transparency box I can't click OK. (I can't click OK even if I don´t uncheck the transparency box)
Something seems wrong with the elevations settings...
Do you have any idea?
DGSketcher
Legend
The elevation marker layer is probably locked.
YES! That was the case! Thank you so much!!
