Hiding PM9 gridlines
Playing around with this new PM feature (the gridlines) and trying to have some of them blocked and others showing. It seems that the only ones that are blocked are the ones that "drawings" go through. Unfortunately, sometimes I have text that spans gridlines, and I would like to turn off the gridlines there.
So far the only thing that has worked is to use a "blank" drawing in the background to span the gridline. This option, however, creates some other headaches.
Is there a simpler way? Is there a way to have PM text and maybe fills turn off the gridlines, and if not, shouldn't that be an option?
0 REPLIES 0
