Haneef Tayob
Published file names not updating
Hello
Currently when I publish a layout called say "B2-02 Stairs" from Plotmaker to say PDF, the name of the published file is named eg. "B2-02 Stairs.pdf"
If I then do a revision to the drawing and rename the layout to "B2-02 Stairs rev1", the published file name remains "B2-02 Stairs.pdf" and not "B2-02 Stairs rev1.pdf" as I hope.
Is there a way to allow the published file name to update to the revised layout name without having to remove and then re-drag it into the publish set.
Thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
3 Replies 3
Djordje
Looks like not.
Check your Publisher set; the names of the layouts in the Publisher list are what the names of the published PDFs will be.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Haneef Tayob
Checked that. Am I missing something?
I've attached a screen shot to further explain the problem.
As a workaround, I've been deleting & then re-inserting the layout. This is not such a problem for pdf conversions, but conversions to autocad become an issue as I've got different publishing options for different drawings.
regards
Haneef Tayob
TomWaltz
regards
The publisher does this pretty consistantly. I believe it's meant to work with PMK's to prevent renaming views from messing with views placed into Plotmaker. I suspect this crept into DWG, PDF, and other formats as well.
Tom Waltz
