Hotlink AC10
I have A.pln and B.pln. "B" are hotlinked stories of "A". Now I'm trying to insert a "B" view into "A" Layout and looks like is making the process but it never ends. Here's what I'm doing: I model one building which is going to be repetitive in the project, but I need a key plan showing how the typical building connected with the others. Then my model bldg. is "A" and the file I created as key plan is "B".
Other issue is I have two roof alternatives. How do you work around with that? So far I "save as" my first alternative building as second one and draw my second roof and then import the roof view to plotmaker. Now that I'm using AC 10 is not working like that anymore, or I'm wrong?
0 Replies 0
