Hotlink dimensions are the wrong scale
Helen123
Hello everyone, I need your input incase there is a solution to this. I have a file that is hotlinked whose dimensions are for printing at 1:50. When the file is hotlinked to the other file, I want the plans to be at 1:200. Is there any way I can have the dimensions appear properly without having to create a new layer for the dimensions at 1:200? Thank you very much!
Thank you Gerry for your answer!
Gerry Leonor
it's a pretty big difference going from 1:50 to 1:200. any notes/labels/dimensions you create in one scale will not necessarily show correctly in another.
that's going from a typical Room Plan scale to a Site Plan scale.
yes -- definitely create separate layers for notes between different scales.
https://discord.gg/XGHjyvutt8
