How can I set the simple ID-label to show the text rotated?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2016-12-07
09:43 PM
ā2023-05-19
03:52 PM
Gordana Radonic
ā2016-12-07
09:43 PM
AC 25 SWE Full
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-12-08 03:13 AM
ā2016-12-08
03:13 AM
In the label settings there is an option to make the text "always readable".
That should be what you are after.
There are also options for how the label is rotated when placed.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-12-08 08:22 AM
ā2016-12-08
08:22 AM
Barry wrote:Kind of tried that a thousand times...got some grey hair in the process. Didn't work for me!?
AC 25 SWE Full
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-12-08 08:51 AM
ā2016-12-08
08:51 AM
What label are you using and how are you placing it (i.e. manually or via "label selected elements" command).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-12-08 08:32 PM
ā2016-12-08
08:32 PM
Barry wrote:Identification label and both manual and auto. 89 degrees is fine but at exactly 90 the label text screws up. I guess it's by design but it is really ugly. I think the text should be rotatable...
AC 25 SWE Full
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-12-09 01:18 AM
ā2016-12-09
01:18 AM
The 'Always readable' option doesn't seem to work on that label.
It does on the 'ID' label but that is basically just text with an arrow and is not a scripted object.
Setting the 'Identification Label' to 'Vertical' works so long as your wall is vertical or just 'flipping' the label works too but that means it will change the side of the wall it is on.
Custom angle of 90 seems to be working for me but again only good if the wall is vertical.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2021-03-23 01:56 AM
ā2021-03-23
01:56 AM
Did anyone figured this out so far?
I am using ArchiCAD 24 and still don't see any label that rotates text.
