How to break the sentence in two lines at detail marker.
Dear Friends
I need a suggestion regarding the 'detail marker' (text)
The text for a detailed marker is going beyond the Marker. (see Fig1 )
I want to write the text in multiple lines (See fig-3)
There is no option to Break the sentence in two lines.
Please help me to fix the issue.
Avi
DGSketcher
Legend
The detail marker is intended to be used as a linking marker typically displaying an ID and link to a layout sheet, you appear to be trying to use it as a label. I think you need to ask why you are highlighting this element, decide what you are trying say to the viewer, then either create a simple detail link or label the element with an appropriate description.
Sometimes (not all the time) you can add "\n" (without the quotes) to the text where you want the line break.
