jrmrt
Create Link to Between Label and Specific Drawing
Hello there,
I was wondering if you could make a Label object work in the same way that a Elevation or Detail Marker works.  When you PDF a drawing set, the Elevation, Section and Detail markers become clickable links to whatever drawing view they are associated with.
I would love to be able to do the same thing for the Wall, Window or Property Labels, so that they can take the viewer directly to the sheet with our assembly types or the window schedule without having to search through the drawing set.
Is something like that possible?
Thank you for any input!
Operating system used: Mac Apple Silicon 12 Monterey
Setup info provided by author
JeffH
This is an intriguing idea.
I think this should be a a legit voted on wish, if it already hasn't been cracked and is possible
AC24 / AC26 / AC27
Win10
