How to reset Check Linear Overlap results?
Mats_Knutsson
Mentor
It's very sticky...so sticky I can't get rid of it in 2D nor 3D...!?
AC 25 SWE Full
Andrii Levko
 You can delete or hide results using  Document >> Issue Organizer.
Andrii
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
Andrii Levko
Andrii
Mats_Knutsson
Mentor
Ah. Stupid me. I don't use the issue manager so I tend to forget it's there.
AC 25 SWE Full
If it helped, than you should click it as solution for helps other users.
